for peopel who have to ford inj's
Old Feb 16, 2002 | 10:22 PM
88greyiroc's Avatar
ok i don't completely understang if my car cam factory with 19 pound fuel injectors and i put fordmotorsport 19pound fuel injectors in it how will that make my car run like crap?the flow might be different because ones ford and ones chev but i figured i could put them in without having to do a whoel lot of tinkering. is it that much of a hassel?i am not going up to 30pounds or nothing
Old Feb 16, 2002 | 10:27 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
If you're still using the same computer then yes, it "could" make the car run like crap. The ford injectors are rated at a lower fuel pressure so with GM fuel pressure the 19lb injectors will actually flow more like 21lb injectors which will make your car run rich unless you compensate.
Old Feb 16, 2002 | 10:43 PM
88greyiroc's Avatar
OOPS I MADE A MISTAKE MY CAR IS A 350 TPI.SO IT HAS 22POUND INJECOTRS ON IT. sO THOSE FORD 19'S SHOULD WORK SHOULDN'T THEY?WITHOUT ANY MODIFICATIONS TO THE COMPUTER?I REALLY WISH A PERSON WHO DONE THE SAME THING I AM GONNA DO COULD TELL ME HOW IT WORKED FOR THEM.
Old Feb 16, 2002 | 11:20 PM
Should work just fine then. You might bump the fuel pressure up a couple notches if you have an adjustable fuel pressure regulator.
Old Feb 17, 2002 | 07:08 PM
88greyiroc's Avatar
does anyone else have any input on this?my car right now smells like a skidoo and idles up and downthe mechanic said my fuel injector is stuck open.Doy ou guys think the new ones will show me alot more performance and gas mileage?
Old Feb 17, 2002 | 07:52 PM
88TAJeff's Avatar
Car: 88 T/A
88, if your car smells like a skidoo, I'd just go ahead and change those inj's right away or you'll end up with gas in your oil. You'll then be asking " what's that knock that I hear along with that gas smell?" Besides, I've been following this to see if I should get those same injectors
Old Feb 19, 2002 | 08:23 PM
88greyiroc's Avatar
What does it mean when the knock sound comes?That doesn't sound like a good sound. I haven't found any gas in my oil but my car does idle a bit weird.Explain the knock to me i have the ski doo smell.
Old Feb 21, 2002 | 11:52 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I used the 19 lb ford injectors in my 305 and it ran fine...I didn't adjust the fuel pres. at all. The 165 ECM has an amazing ability to adjust the fuel to get the correct mixture.
If you havea 350...I'd adjust the fuel pres. so that the injectors are flowing about 22 lb. Shouldn't have to bump it up much.
I have no idea why it's idling funky. You might do a leak down test on the fuel system to see if it's losing pres. too quick. Hook a fuel pres. gauge to it. Turn the key on. Let it go up. Shut the key off and see how long it takes to drop. If it drops in a hurry...you have either leaky injectors or a pump with a bad check valve.
Old Feb 21, 2002 | 12:33 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Another possibility is that you either didn't seat the injectors properly or tore an O-ring seal...either of which would give you a vacuum leak...
Or its possible you do have bad injectors. However, adjust the fuel pressure first. The engine can adapt a bit, but without adjusting the fuel constant (for both injector banks) in the BIN, then you are forced to deal with a manual solution to your problem.
Good luck.
Old Feb 21, 2002 | 06:23 PM
88greyiroc's Avatar
i haven't put the injectors in yet.What i meant by idling funny was the car will idle nice for about 5 minutes then it will idle low almost to a stall then it will idle back up nice and keep on doin the same thing over and over.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
KCG
Jun 24, 2020 04:33 AM
mcbitchman
Sep 29, 2015 12:32 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
