what's the biggest cam for 1988-89 305 TPI ?
Old Feb 20, 2002 | 04:41 PM
Smorgousford's Avatar
what's the biggest cam that you can install in a 1988-89 stock 305 TPI manual and still have it be a daily driver but get as much hp as possible. The stock cam is: Lift- .415/.430
Duration - 207/213
Lobe Sep - 117.0
and it's a roller cam
Old Feb 21, 2002 | 11:44 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I have a 305 TPI w/08-302-8 cam in my IROC. Mildly ported heads and get 215 hp/279 torque at the rear wheels with an auto.
I think the heads will be the limitting factor. I'd probably go a little smaller the next time I did it...something in the 220 dur range with .46 or so lift.
Old Feb 21, 2002 | 01:33 PM
thanks for the info
Old Feb 21, 2002 | 06:39 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Re: what's the biggest cam for 1988-89 305 TPI ?
Duration - 207/213
Lobe Sep - 117.0
I'm running the Crane 2031 Compucam in my '87 305 Roller motor. It specs out at -
Lift - .432/.459
Duration - 208/214
Not sure on the LSA, but the computer doesn't mind it at all. Passed NJ emissions with flying colors. I'm also using World Products S/R Torquer heads. The combo is in an '85 Monte SS with an auto trans and 3.73 rear.
Hope that helps!
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
