Cleaning, honing, porting runners?
Old Feb 20, 2002 | 07:28 PM
brian89transam's Avatar
Is there a fairly easy way to do this? I was thinking maybe some kind of a small engines cylinder hone with an extension would work? What do you think? How much can the stock runners be ported? Will they still fit the gaskets? I thought this would be a great idea for some cheap hp, but I'm not sure yet.
-Brian
Old Feb 20, 2002 | 07:46 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
When I had my stock runners I did the following. It ground the material where the runner meets the flange of the runner. Though it's probably only a 1/16th or 1/8th of an inch, I figured times that by 8 and it's probably worth something. I also opened those flanges up some to match the larger ports of the intake after I finished with those. I believe in the "every little bit helps" theory.
mrestrictrplate
Sep 21, 2015 11:24 AM
ericjon262
Sep 11, 2015 06:07 PM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
89fast5oh
Sep 8, 2015 09:55 AM
