should i buy a mini ram?
Old Feb 21, 2002 | 02:50 PM
hello's Avatar
can you guys give me your thoughts on the mini ram is it actually woth buying?
Old Feb 21, 2002 | 02:57 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
No... Just go Lt1, Its WAAAAAAAAAY cheaper, and almost just as effective!
Old Feb 21, 2002 | 03:08 PM
hello's Avatar
isn't there alot of work involed in making a lt1 intake work i heard the bolt patten is different?
Old Feb 21, 2002 | 06:44 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
it's less work, cheaper, and just as effective as a miniram if you go through this site:
http://www.lt1intake.com
Old Feb 21, 2002 | 07:38 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Less work than a miniram??? Not so sure about that. The miniram will bolt right up. LT1 intake requires a good bit of work for the bolt holes, distributor hole, etc. But cost wise, you can't beat a modified LT1/4 intake. The miniram is a rip off.
Old Feb 21, 2002 | 07:47 PM
Engine: 3.6L
It's just as easy but it's less work to mod the intake if you let John mod it
and still cheaper if you go through www.lt1intake.com .
too bad I live in CA and have to pass visual smog inspections.
Old Feb 21, 2002 | 09:25 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
What about flow/horsepower? Wasnt the LT1 intake designed for a 285/305 horsepower engine? Miniram for a 400+ horsepower?
Old Feb 21, 2002 | 10:05 PM
Kersteae's Avatar
There are people running 10's on unported LT1 intakes. Chances are it'll take you where you want to go. Later.
Adam
Old Feb 22, 2002 | 07:32 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Find John Millican, Hes the man for this..........
Old Feb 22, 2002 | 10:31 AM
Oh well i guess it is just about as easy if you have John modify it. Remember though you still have to mount the remote theremostat housing and do some minor clearancing on the accessory brackets. That shouldn't really be a problem for anyone though.
cowansauto
Apr 3, 2025 12:51 PM
Stangski09
Nov 14, 2015 01:27 PM
Magman
Sep 13, 2015 12:07 AM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
