What type of Injectors.
Old Feb 22, 2002 | 09:16 PM
Formula383's Avatar
Car: 88 Firebird Formula
Need some Help on Injectors
I am looking to see what type of injectors that people are using in there machines? My setup that I have is as followed: 383 Motor..Dart II Heads..Intake 227 Degrees at .050..Exh 232 Degrees at .050..Lift intake 512 w/1.6's..Exh 510 lift w/1.5's..Slp Headers..ASM Large Runners..ASM 52MM..ASM Chip..Ported Plenum..24lb injectors..3.45 gears..Gutted cat w/flowmaster muffler..I'm running low 13's right know..Am going to be changing the gears to 3.73..Any and all help would be gratefull.
Old Feb 24, 2002 | 12:15 PM
Formula383's Avatar
Re: Need some Help on Injectors
!!!!!!!!!!!!!!PLEASE HELP!!!!!!!!!!!!!!
Old Feb 25, 2002 | 09:31 AM
primo's Avatar
Your injectors may be find, check if you are running lean or rich, you can also play with your fuel pressure before changing injectors.
Old Feb 25, 2002 | 10:03 AM
Formula383's Avatar
If the injectors needed to be changed what lb injectors??
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
dusterbd
Sep 29, 2015 08:40 AM
