? about vacuum nipple under T.B
Old Feb 24, 2002 | 10:57 AM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Do you have to have a vacuum line hooked up to the nipple under the TB on an 88 TPI? I have mine plugged off, and for some reason I get this feeling I shouldnt have Any response would be greatly appreciated.
Old Feb 24, 2002 | 12:27 PM
89BlueTA's Avatar
Mine is hooked up on my 89, it runs from a vauum block that is hooked to the EGR, I thought that was were the exhaust gas was reintroduced into the intake. I could be wrong though.
Nick
Old Feb 26, 2002 | 12:31 PM
Vader's Avatar
TPI,
89Blue is correct. That vacuum nipple is teh source for the EGR solenoid and EVAP purge lines on most TPI engines. You might get by without the EGR, but you should still purge the EVAP canister if you don't want it ti saturate with fuel and start smelling up the neighborhood.
Old Feb 26, 2002 | 03:11 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Ok, 89 says the exhaust gas is introduced back into the intake throught that tube. Did I read that right? Did Vader?
Old Feb 26, 2002 | 05:57 PM
89BlueTA's Avatar
Yes thats correct, remember the two humps inside the plenum that everyone cuts down, thats why they are there. The EGR port is right behind them.
Nick
Old Feb 27, 2002 | 10:04 AM
Car: 1991 Firebird
Engine: 427 LSX
Dude, are you saying exhaust gas is dumped directly into the intake at those humps???????
Old Feb 27, 2002 | 10:07 AM
camaro6spd's Avatar
si
Old Feb 27, 2002 | 10:27 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Wait, you people are confused.
The vacuum nipple coming off the bottom of the TB is a ported vacuum source for the EGR solenoid which controls the EGR valve. (and if vader says it also does the canister dump too, i'll take his word for it on MAF cars)
The EGR gasse come up through the intake base, through the tube in the runners, and enter the plenum through the 2 big holes behind the TB openings (behind the humps)
Old Feb 27, 2002 | 12:30 PM
Car: 1991 Firebird
Engine: 427 LSX
right Ed, I wasn't confused. Please don't group me in that catagory. I thought people were saying the recirulated exhaust was carried through that little plastic tube. And they were.
Old Feb 27, 2002 | 08:04 PM
360Iroc's Avatar
Can someone go into more detail about the gas smell, i blocked my egr when i built my motor and after a while (about 2 months) the canister was very saturated, to a point that it leaked like it was a gas tank with a hole in it. help would be apprieciated, im about to do the exact samething on my iroc
Old Feb 28, 2002 | 08:02 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
ummm??ok??
so can i run a vacume line from this nipple to the vacume port on the EGR?
Old Feb 28, 2002 | 08:19 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
No, you cannot. The vacuum source goes to the solenoid. If you run it directly to the egr valve, you will have some truly interesting drivability problems........
The solenoid sits down on the intake, at the back between the dist, and the coil. It has a connection from the ecm (electrical) and the vacuum lines for source (from the intake) and one running to the egr valve. IF none of that stuff is there, and you are not getting any codes, don't worry about it.
The cannister purge, however, does need to be hooked up.
Old Mar 1, 2002 | 01:27 AM
89ProchargedROC's Avatar
or you can just take off all that EGR stuff and not worry about it
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
