Trimming gaskets to match runners...
Old Feb 25, 2002 | 09:35 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Anyone done this? I am talking about the runner to base gaskets, 2 per side. The new gaskets allways seem to be smaller in diameter compared to the intake openings. I am doing port work and siamesing now, just thought about trimming the gaskets a bit to match the runner opening.
Any major issues stopping me?
Old Feb 26, 2002 | 12:24 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
No problems with that at all...... Just keep an eye on how much of the gasket you take off so you don't make it too small to seal. I really have to agree that the mass production process used for these intake systems resulted in some extremely poor fitting components and gaskets ..
I port matched everything on my car after I siamesed the plenum and matched everything in the intake system accordingly - TB, plenum, runners, base, and all gaskets. Some joints were fine and others needed a lot of work. Pretty much free ponies.....
I ended up using a set of Big Mouth gaskets as they have a lot more meat to play with than the OEM ones.... Plus the OEM ones have a metal inner part that is kinda a pain to trim....
Good Luck,
Matt
Old Feb 26, 2002 | 09:02 PM
Car: 1988 IROC-Z
Thanks Matt. Since it is a dry intake system, I didn't think it would be a problem. I will try and use a good pair of dikes to trim them up a bit. I think I only need to take off about 1/16".
If I get any leaks, then a bigger set of gaskets will be ordered!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
sheachopper
Jul 31, 2019 11:27 AM
rusty vango
Sep 29, 2015 02:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
