WOT...what affects Air/Fuel ratio?
Old Feb 27, 2002 | 02:34 PM
Little GTA's Avatar
WOT, what affects Air/Fuel Ratio?
Old Mar 1, 2002 | 05:08 PM
Little GTA's Avatar
Bttt
Old Mar 1, 2002 | 10:45 PM
Guest
Guest
Posts: n/a
Aside of trivial things that can affect it, the computer. The program on the chip has control over it for the most part. If you want to change it, thats the correct way to do it. You can lie to the engine and raise or lower the fuel pressure, which will affect the A/F ratio at WOT, but it will force the computer to make adjustments at part throttle that it ideally and normally wouldnt.
Old Mar 2, 2002 | 08:07 AM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
nothing controls AFR at WOT. when the computer senses WOT, the injectors stay open until a less than WOT condition returns in which the O2 sensor will take over control again. almost like open loop mode with more aggresive timing. whatever your chip has programed for WOT, timing etc. is what you get. if your experiencing a slightly lean condition you could bump the FP to help. if you have some serious mods your gonna need a new chip and larger injectors
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
