Afpr ?
Old Feb 28, 2002 | 09:47 PM
Casey'91Z28's Avatar
Afpr ?
I just installed a Holley AFPR and I set it to 46 PSI(stock was at 42 PSI). I drove it around and felt like it pulls a little harder so I was happy. But when I went to drive it later it had a hard time starting. I hope this isn't a sign of my fuel pump going out. Should I just lower the pressure?
Old Feb 28, 2002 | 11:55 PM
87transam5.7tpi's Avatar
I don't think that would do it, I'm not sure. but my fuel pump (which is a stock replacement) pumps over 90psi. but like I said I'm not for sure wif that
Josh
Old Mar 1, 2002 | 09:52 AM
IROC57TPI's Avatar
Fuel pressure setting......
I have a problem similar that started when I installed the AFPR. I since have diagnosed it to be a sticking injector. Higher fuel pressure tends to clog old injectors.
Mine have 160,000 miles on them. I'm having them rebuilt and balanced.
A sure way to tell if yours are sticking is to take off the intake duct and open the throttle body with the car not running. Listen for the fuel bleeding off..... you will hear it if one of them are sticking. :lala:
Old Mar 1, 2002 | 09:17 PM
Today I noticed that when I started it up there was a strong gas odor from the exhaust.
Old Mar 3, 2002 | 10:54 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Just by raising your fuel pressure you are not going to increase performance. I actually had to lower mine to pick up performance. I am running at about 34 or so and mine pulls harder than ever. We actually ran a scan tool to see exactly how well my car would be running at what fuel pressure.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
