LT1 intake possible coolant leak???
Old Mar 1, 2002 | 10:09 PM
cfabe's Avatar
I'm in the process of converting my lt1 intake millican style. I've got all the bolt holes filled and just put on the gasket to mark where to drill, but i think the coolant ports in the intake gasket are way to close to the edge of the manifold for a good seal. Has anyone else noticed this and is there a solution? I havent heard any mention of this being a problem before.
Old Mar 2, 2002 | 08:06 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I always used RTV around the coolant holes on the head anyway. LT1 intake or not.
I also highly recommend it with this intake. There is material there just not alot. The ones I have done have not leaked except for my protype one that I'm running. See the coolant passages in the TF heads are smaller then stock heads. The coolant fittings I screw into the intake came in contact with the head and forced the intake away from the gasket causing a leak. I had to shave off some of the end of the fittings and use RTV around the holes. no problems now. I have been running it 6 months.
Old Mar 2, 2002 | 10:06 AM
cfabe's Avatar
Ok, thanks for the reassurance... RTV it is.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
