fuel pressure gauge help...asap
Old Mar 3, 2002 | 02:38 PM
88IROCZ350's Avatar
I'm getting ready to install my electric fuel pressure gauge i just got the other day and opened the box and found nothing to connect the sender to the fuel rail. Whats the best way to go about this and what parts did u use, where did u get it and what was the part numbers. Thanks for your help guys.
Old Mar 3, 2002 | 07:54 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Here's a link to a post I made on this very thing.
https://www.thirdgen.org/techbb2/sho...637#post533637
What gauge do you have, Autometer?
It's fairly simple. You also have to decore the schrader valve. The centre section of the valve unscrews and becomes an open fitting.
Hope you get it sorted.
Robert
Old Mar 3, 2002 | 09:02 PM
88IROCZ350's Avatar
ok... i have read that post before but that doesn't anwser my question, i dont' know anything about braided hose. I noticed in jegs they have a 3ft. piece of braided hose that is 3/16in Diameter. If i buy this do i have to get the ends to put on it or does it come with 4AN fittings? thanx if ya can help
Old Mar 4, 2002 | 08:34 AM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
you can go the easy way but it'll require buying a kit from summit. go to summit and do a search for "fuel pressure kit" or something like that. its a kit that says its for their guage but its universal. something like 20 bucks. comes wiht about 2 feet of braided hose with fittings, and a few other universal fittings.
when you get it, decore your schrader valve just like the guy above me said. be sure to release the pressure on the schrader valve first, do this carefully and it'll take a little bit of time.
the fittings on the braided hose are 4an, so hook one end onto the schrader valve and hook a 4an -> 1/8 NPT onto the othe rend. then hook the 1/8 NPT onto your sender. badda bing, badda boom. costs you a little more money but it makes things a little easier.
Old Mar 4, 2002 | 11:39 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
That's what I did....
Old Mar 4, 2002 | 05:24 PM
88IROCZ350's Avatar
thanks for the help guys.. thats what i'm going to do then
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
