TB question
Subscribe
Mar 3, 2002 | 06:07 PM
What is the difference between throttle bodies from 84-88 and 89-92. Will a aftermarket one for 84-88 fit one for later (89)?.
I ask this because I can get a deal on a 58 MM BBK , but it is for 84-88.
Nate
Reply 0
Mar 3, 2002 | 06:37 PM
The difference is in the IAC passage in the plenum, An early model TB (85-88) cannot be used on a late model plenum, because of the lack of IAC passage in the plenum. You could use a late model TB on an earlier model PLenum though.
nick
to use the Tb you would just have to get an earlier plenum with it, but then the plenum would have a cold start passage. But I think that would just be blocked off by your late model runners and would not be a concern.
Reply 0
Subscribe
