Another TPI L98 in the 12's!
Old Mar 3, 2002 | 07:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Finally, after 9 months I drive my car into the 12's! With a 1.923 60', I ran 12.803 @ 108.50 MPH. My mods are in my signature. I used ET Streets, and launched around 4000 RPMs. And yes my T5 took the abuse (so far...). No I havent put those SLP fully-siamesed runners on yet, this time is with the TPIS long tube runners. Hopefully those runners will be done soon... Believe me I'll post when I have info with those.
Old Mar 3, 2002 | 07:27 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
Congrats on breaking into the 12's. It looks like theres more in it with a 1.9 60 ft time. How bad did you spin off the line with dumping the clutch at 4 grand?
Old Mar 3, 2002 | 09:45 PM
David 91RS/Z28's Avatar
Congrats Kevin!! Way to break into the 12's!
Old Mar 3, 2002 | 11:15 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Re: Another TPI L98 in the 12's!
Right on, man!! I guess it was just a matter of having the right tires to go with all that torque. I like your setup too, I got a few cues from it. I doubt I'll be able to compete with your trap speeds when I run at the track this spring, cause of the slushbox, though I'm hoping for 12's.
Old Mar 4, 2002 | 03:53 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Glad you finally got into the 12's. That sig was 13.23 for such a while.
Old Mar 4, 2002 | 07:04 AM
Guest
Guest
Posts: n/a
He thought it was alot worse than it actually was, I can tell you that much. Looked to me like there was a slight amount of spin, but IMO just the right amount. Just enough to keep the RPM's up until the car got moving. First couple times he let off Then he kept his foot in it, and what do you know... 12's!
Pablo and I were there to witness it, was too cool. Maybe it was the peer pressure that put Kevin in the 12's
Old Mar 4, 2002 | 02:36 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Good job man! I got a question for ya, how far can you rev her tell you stop making power?
Old Mar 4, 2002 | 02:40 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Sweet!! Tell me how with 419 ft lbs of torque on tap you can launch at 4000 and not smoke the tires?? And if you didn't smoke the tires (which it doesn't sound like you do) why is your 60 foot only a 1.9xx???? I launch at idle and can run that 60 foot. And many cars with way less power than yours can beat 1.9xx. I am interested to know.
Old Mar 4, 2002 | 11:35 PM
Kevin91Z's Avatar
Sheeeit... I finally get a 60' better than 2.0 and you guys are chiding me for only getting 1.9's! For the record, I had a 1.88 as well. I have no idea why my 60' times arent better, other than I'm still a bad driver. I let off the first couple times because I thought I felt the tires spinning. The car doesnt plant the rear tires like it should, and I'm sorta babying the T5. Once I put in the T56, and my dad custom-builds me a torque arm, I should be able to launch at 5000+ RPMS and really plant the tires.
As far as what RPM I stop making power, according to the dyno the power peak is at 4800 RPMs. I shift it at 5200 RPMs and go thru the lights at 5000 RPMs. I have a 9-bolt with 3.70 gears.
Old Mar 5, 2002 | 08:43 AM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Waz sup biznich, Dude, I need a t-56 soon because my T-5 is going to be going out. It gives a gring going into 3rd gear. It already been rebuilt 3 times.
Anyway, the strip opens here March 14 and Ill be there.
I dont have the $ for slicks and I know I cant get 12's with out them.
Old Mar 5, 2002 | 05:46 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
re
Great to hear that Kevin. You've got mail. How long do you think that rearend and T5 will last?? Well, hope to hear from you soon thru email. Had a few questions for ya. Later
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 19, 2015 10:07 PM
Sanjay
Aug 12, 2015 03:41 PM
