MAF codes dispite changing everything under the hood!!!
Old Mar 3, 2002 | 10:04 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My GTA was throwing a code 36, along with the occasional code 34.
To get rid of the code 36, first I replaced the battery, then the burnoff relay, then finally the MAF.
Still had a 34 though.
I replaced the MAF relay yesterday and I was code-free for the first time since I bought the car.
It lasted a day. Tonight it popped a code 33 on the way home.
Now that I've got new relays, and a new MAF, and the wiring appears to be ok (I haven't done a continuity check yet), what should I be looking for?
Old Mar 4, 2002 | 07:06 AM
Guest
Guest
Posts: n/a
Check the minimum air and TPS setting. Try dropping the TPS setting below the .45v mark if its not already there.
Old Mar 4, 2002 | 01:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
http://www.deadbird.org/tech/33code1.gif
http://www.deadbird.org/tech/33code2.gif
May/may not help...
Old Mar 4, 2002 | 10:38 PM
385TPI's Avatar
MAF codes
You might try checking your VSS sensor. When I was working all the roddents out of my project truck w/ a 385 tpi I did not have a VSS set up in my system. For almost a year I chased all sorts of intermittent problems and most wore MAF related. I ended up buying a VSS sensor kit fom Street and Performance. After I reset my initial idle I have been problem free for 60,000 miles. Just a thought! Hope you get it figured out.
89GTAOz
May 16, 2020 09:31 AM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
