Looking for a elbow for carb manifold
Old Mar 6, 2002 | 07:38 PM
tntcorvette's Avatar
Im looking for a elbow for a carb manifold so I can bolt up my 58 mm throttle body.
Does anyone have a url on the internet so I can see the dimensions of it to make sure hood clearance is not an issue?
Old Mar 6, 2002 | 07:51 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I don't know if you have an auto zone near you or a similar store where you can page through the perfomance books but, at auto zone here I saw that but, don't remember who makes it accel or holley?? some one like that I saw it though I think it had the mesurments too!
Old Mar 6, 2002 | 10:51 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Yo tnt, what intake or u planning on using?
Old Mar 7, 2002 | 05:19 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Accel makes it around $250 I think its either 5.5in or 6in tall.Or you could make one like I did took a TPI plenum cut it in half right behind the the second runner hole on the passenger side.Cut a hole in the bottom of the plenum. Then welded a 2in carb spacer to the bottom of the plenum and a plate to the back where it was cut in half,made a plate to cover the two runner holes left on the passenger side of the plenum.Drill and tap the side plate for the vac fittings that you'll need,then bolt on the side.Its 5in tall.Cost me about $150
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
makaveli09
Sep 15, 2015 10:43 AM
rjcme
Sep 5, 2015 01:23 PM
