LT1 TB on TPI plenum
Old Mar 9, 2002 | 11:07 AM
JuGrNuT350's Avatar
Will a LT1 TB work on a TPI plenum as far as bolting up goes?? what about the IAC & TPS sensors are they the same from SD TPI to LT1? Would you need a throttle cable from a 94-97 LT1?
Thanks,
-Timbo-
Old Mar 9, 2002 | 03:44 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, the LT1 TB will bolt onto a TPI.
The IAC and TPS sensors anr the same electrically, just differant connectors. So there's more work to change the connectors on the TPI harness. Pretty easy though.
You will have to run the LT1 throttle cable too.
Old Jun 12, 2002 | 11:57 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
does anyone know where to buy the lt1 harness connectors for the tps and iac so they'll work with tpi?
Old Jun 13, 2002 | 05:15 AM
Engine: 4.0L
PepBoys
Old Jun 13, 2002 | 06:02 PM
Car: '87 Camaro LT
Engine: 355 L98
Does anyone know the part number/vendor for the lt1 iac pigtail? I called pepboys and got a case of "it's not in the computer, bring in the old one" and they don't have a catalog either.
midge54
Dec 27, 2019 04:14 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
