Am i right on this ?????
Old Mar 10, 2002 | 10:53 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Okay, i think i am right about this, just want to get a second or third opinion. When i switch over to TPI the chip that's in the donor ECM will not work in my car? And the one i have now will work? The donor ECM was out of a 89' IROC, 350 automatic. I have a 350, 5 speed with a hyper tech stage 2 chip which works fine with the current set up i have now. Am i right about this?
Old Mar 10, 2002 | 11:38 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
No you can't use your TBI chip on TPI and you can not use a automatic chip on a manual. I can burn you a stock chip for cheap if you want.
