TPI plenums any differance 85-92
Old Mar 12, 2002 | 08:46 AM
Pino91Formula's Avatar
I was wondering if there is actually any differance between plenums from 85 to 92
Old Mar 12, 2002 | 09:37 AM
BitchinCamaro's Avatar
Off the top of my head, in 88 or 89 the lines on the top got shorter, about that time the cold start hole dissappeared. In '90 they got a port for the MAP sensor. I think you can fairly easily use any plenum on any year with some simple modifications.
Old Mar 12, 2002 | 06:40 PM
Omar's Avatar
85-88 are all the same. IAC inlets at front of plenum, and cold start injector passages.
89 - the IAC inlets blocked off front of the plenum. Also, cold start injector passaged was eliminated on the driver side.
90-92 Same as 89, but add a MAP sensor boss over by the fuel pressure regulator.
Purely cosmetic - 89 and later received the shorter grooves on top.
Old Mar 12, 2002 | 09:46 PM
Blackened's Avatar
What does the cold start valve have to do with the plenum ?!?
MantyZ28
16
Dec 21, 2015 11:02 AM
masonta
Aug 31, 2015 10:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
