Disappointing SLP runners
Old Mar 12, 2002 | 10:45 AM
BitchinCamaro's Avatar
My runners showed up today and I have to say I am disappointed. They looked great at first, but then I pulled out the gaskets. They are simply the standard tpi gasket, for some reason I thought they would be siamesed at the top. I test fit the gaskets, no where close to right (see pic) there is not one centimeter of it that matches up. It is not the end of the world, I planned on porting and gasket matching anyway. As for the bolts, why couldn't they just add the 2 more for the complete matching set?
Old Mar 12, 2002 | 11:06 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You are kidding, right?? The gaskets are normal probaby because of the factory plenum is not siamesed.
J
87transam5.7tpi's Avatar
I"m very sorry man, I had only heard good things about them. thats why Iset up the GP. sorry again
Josh
Old Mar 12, 2002 | 11:24 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I have never heard anything good about them. Oh wait, they are inexpensive.
Old Mar 12, 2002 | 01:00 PM
91-ZZ4-Z28's Avatar
I have SLP runners and I like them. Just order sone gaskets from Linenfelter ($12) they have custom cut MR. Gasket sets for large tube runners. The gaskets are flat and have no ridges around the ports so it is easy to trim them to match the runners perficly and they seal fine. I ported the runners out and siamesed a little deaper and they are a good.
Old Mar 12, 2002 | 01:07 PM
I am going to port and gasket match, they will be great then. (Especially for the price) I am not upset, I just expected a little better for SLP. As for the gaskets, the fact they are stock isn't the big problem, its that the don't match up at all. They are NOT uniformly too small, if you look at the picture you will see the upper right section is too big in some areas and too small in others. (ie. the runners on are not uniformly round and/or not centered properly)
87transam5.7tpi : Thanks for setting up the GP, you saved me some good cash, no reason to apologize.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
