TPI Injectors
Old Mar 19, 2002 | 06:24 PM
SLOW91TA305's Avatar
TPI Injectors
I have 3 bad injectors on my 91 TA 305.
I don't know if I should just replace the ones that are bad or get a new set. And if I get a new set, should i go with 19lbs or 24 lbs since they cost the same.
So my question is will my car run rich with 24lbs injectors? Should I stick to stock to be safe? Would 24lbs be a better choice with an AFPR?
thanks
Old Mar 19, 2002 | 07:35 PM
ScreaminDeamin85Z's Avatar
i dont know what you should do but i do know that you will run rich with 24#s if the prom is not changed. also having no mods i would get the 19#s. thats what i switched back to after i got tired of fouling plugs with the 24#s.
Old Mar 20, 2002 | 10:35 AM
IROCKER's Avatar
Without any drastic mods I would stick with your 19# injectors for now. The 24# ones would be overkill and may hurt your performance.
Steve78LT
Feb 24, 2016 12:15 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
