Will these injectors on ebay flow 22lb/hr at 45pis as the seller says?
Old Mar 21, 2002 | 10:52 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
http://cgi.ebay.com/ebaymotors/ws/eb...406817&r=0&t=0
I will be using them in an 1989 L98
Old Mar 21, 2002 | 11:52 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Yes, ford rates their injectors at a significantly lower fuel pressure (36 psi) than GM (about 44 psi). Those are the exact same injectors i bought when i was replacing the injectors on my GTA and i haven't had a problem. They are a little shorter than the stock injectors but they still fit in the manifold and fuel rail fine and don't leak. Out of curiousity i brought along the auto xray for a little test drive with the new injectors and the BLM/INT values were basically same as they were before.
92projectcamaro
Jan 18, 2016 08:00 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
BAMiller
Sep 14, 2015 06:38 PM
tmellott89
Aug 16, 2015 02:58 PM
