What to Do ?????
Old Mar 24, 2002 | 08:22 PM
91 z28 350's Avatar
Car: 91 Z28
What to Do ?????
My car is a 91 z28 with a 350 has 50,000 original miles and is my daily driver, so far i have slp headers, flowmaster catback, and a airfoil, next i wanna port my plenum, get intake runners and intake base. After that i plan on getting heads and a cam, what runners, intake base, heads,and cam should i get. also what kind of horse power am i looking at after this is all done.
Old Mar 25, 2002 | 11:34 AM
tpi_roc's Avatar
You're running TPI, be more concerned with torque than hp or you'll ge discouraged reallllllllllly quick.
As far as intake setup
Mike davis has a 12 second 350, not to mention in a heavy car using a ported edelbrock base and i believe TPiS runners.
I think TPiS is a huge ripoff, but he's going for a stock apperance
without those limitations i'd say Edelbrock base, SLP runners, and port your intake
Heads all depend on what power you want and where you want it
You could even get vortecs and a scoogin base, i think thoes are in 12's and the heads are cheap as heck.
anyways, good luck
Old Mar 25, 2002 | 12:35 PM
sIcK pUpPy's Avatar
What is the concensus on siamesing the stock base? Thoughts?
JD
Old Mar 25, 2002 | 12:37 PM
tpi_roc's Avatar
It will provide the higher RPM flow if thats whta you're after
Old Mar 25, 2002 | 12:44 PM
sIcK pUpPy's Avatar
I am playing around with the idea. For now i'll retain the factory cam, and clean up the heads. With 3.73's and a factory stall, I guess it should help if I tune the fuel pressure, right? I run 50 psi at 4500 ft above sea level. That nets me alt. corr. 13.90's on my current set-up. Any ideas?
Old Mar 25, 2002 | 02:47 PM
91 z28 350's Avatar
Car: 91 Z28
I was thinking of getting trick flow 23 Degree Heads, 64cc CNC-Profiled Chamber which one out of theses 2 and which trickflow cam ??
TFS-30400005-CNC Heads for 1987-95 350 non-LT1 with 1.25 in. single valve springs, pair
TFS-30400006-CNC Heads for 1987-95 350 non-LT1 with 1.47 in. single valve springs, pair
