v6 TPI
Old Mar 26, 2002 | 12:19 PM
91z4me's Avatar
v6 TPI
Does any know much about the 3.8 TPI v6's?
Old Mar 26, 2002 | 12:36 PM
Jon98's Avatar
do you mean the 3.8 in the 95+ v6 fbody's? if so they are NOT tpi, SFI i beleive.
i use to have a '98 v6 3.8....
Jon
Old Mar 26, 2002 | 02:20 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
2.8 & 3.1 were MPFI
Old Mar 26, 2002 | 02:24 PM
91z4me's Avatar
No I mean the 3.8's that were in the bonnivilles and I think they may have been in buicks or caddies. I have seen Tuned Port Injection on bonniville engines and on the backs of some other cars. Does anyone know what I am talking about?
Old Mar 26, 2002 | 02:43 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
No we don't. There is no such thing as a Tuned port Bonneville. I have a Bonneville and it sure as hell isn't Tuned Port. I also have a Camaro, that is tuned port injected. I believe you are mistaken. Its either an EFI, SFI, MPFI but not TPI. No way to do it... the TPI is for a V8 and a 3.8 is a V6...
Old Mar 26, 2002 | 04:55 PM
polishdevil's Avatar
Car: 88 GTA
In Chilton's 1982-1990 Firebird manual all the fuel injected engines are referred to as TPI, the 2.8, 3.1, 5.0, and 5.7
Later,
Dave
Old Mar 26, 2002 | 05:38 PM
wataru's Avatar
We used to own a '93 Transport that had a 3.8 in it. On the side of the van it said"Tuned Port Injection". One day I noticed it and took a double take. It was just wierd seeing that on the side of a mini van.
Later Barrett
Old Mar 26, 2002 | 06:31 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Wow, i know what your talking about. It was in a front wheel drive car but i can't remember what it was. My sister's ex-boyfriend had one. I also did i double take when i saw "Tuned Port Injection" stamped on top. I keep think it was a pontiac...just can't remember....Reminded me of the Buick Le Sabre in styling cue's...grrr...now i am itching to know what it was....
Old Mar 27, 2002 | 07:35 AM
91z4me's Avatar
Red Iroc just because you don't know it and haven't ever seen it doesn't mean it isn't true. I know I have seen them but I guess they didn't make them to many years. I also heard rumor that the 89 fiero GTP was supposed to have a TPI V6 a 4.3 but the car got canceled. Oh well thanks for you replies I will go digging on my own from here.
Old Mar 27, 2002 | 10:55 PM
Arawn's Avatar
I test drove a '93 buick a while back that had a 3.8 liter TPI in it. A little sluggish. The car was in great condition though, only like 30,000 miles on it.
Old Mar 28, 2002 | 12:08 AM
Swapmaster's Avatar
Starting in 91, the GM front wheel drive's with the plastic upper
intake manifolds are tuned port engines.
Old Mar 28, 2002 | 12:20 AM
Swapmaster's Avatar
Also they never put a 3.8 in a Caddie, though it is a better engine.
Old Mar 28, 2002 | 06:32 AM
u r sofa king we tah did's Avatar
yes, they do exist. its not a long runner design like the V8 TPI though, its more an LS1 style composite intake manifold. heres the specs:
205HP@5200
230FT/LBS@4000
not bad for a 3.8, heavy car though
Old Mar 28, 2002 | 08:03 AM
Swapmaster's Avatar
I just measured one here and the runners are about 7 1/2" long.
5 1/4 in the upper and 2 1/4 in the lower.
Old Mar 28, 2002 | 08:14 AM
Vader's Avatar
As a purely technical matter (despite the NAME put on an induction system) all intakes are tuned at SOME RPM range, so they are all "tuned" systems. If they have port injection, you do the math...
Old Mar 28, 2002 | 09:09 AM
Swapmaster's Avatar
Well, yes and no. The early V6 Buick, 91 and backwards had an intake that consited of basicly a large plemun with short 3" runners which are too short to be considered tuned. But yes you are correct, 95% of intakes are tuned to do a specific job: performance, towing, economy etc. But I feel if the runner is less than 4 or 5 inches long there is no tuning effect to it and will probably suck for anything other than mid to high rpm use.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
