fan bypass?
Old Mar 28, 2002 | 04:18 PM
craiger's Avatar
fan bypass?
how can you put a switch to bypass the fans to turn them on at will?
Old Mar 28, 2002 | 06:51 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Your driver side fan is controled by the fan switch. This has one lead and is located on your passenger side head. Grounding this lead will turn on the fan regardless of what the ECM has to say about it. Putting a switch on this wire while grounding it will give you manual control of the fans opperation. You can also by an aftermarket control unit, like sold by derale, which can switch both fans on and off automatically at changeable temps.
There is tons of cooling info at this link:
https://www.thirdgen.org/newdesign/tech/cool.shtml
:rockon:
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
