Oil in my plenum
Old Mar 30, 2002 | 06:27 PM
86305's Avatar
Oil in my plenum
For some reason it's getting a little oily in there. Anyone have an idea what it could be?
Old Mar 30, 2002 | 11:14 PM
Desert86Roc's Avatar
Normal. Your PVC gasses are routed into the plenum, and they are usually oily.
Old Mar 31, 2002 | 08:44 AM
trigger GTA's Avatar
Car: 92 TA vert
PCV for sure. if you got lots of oil in there it is usally the first sine that your rings are going.
with the engine running pull the PCV out and see how much blow by is comeing out the valvecover
Old Mar 31, 2002 | 10:57 AM
86305's Avatar
The pcv line isn't oily but the line on the drivers side is a little oily i think thats where it's coming from. Can i put a pcv valve on this side?
Old Mar 31, 2002 | 11:07 AM
Car: 92 TA vert
No the other side bring in fresh air into the engine.
Do you have oil and smoke coming out the PCV side?
also check for good suction on the PCV itself.
the other line is used it replace the air that is removed from the PCV side. if you have oil on the inlet side(passenger) then you may have a blocked passage
is there alot of oil?
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
CatmanFS
Sep 19, 2015 09:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
