Installed headers, now too rich?
Old Apr 1, 2002 | 11:20 PM
Germ's Avatar
I just put a set of SLP 1 5/8" headers and a Flowmaster 3" cat back on my '87 305 TPI. Along with it I axed the AC, the AIR, and the cats. (I also had to replace a temperature sensor on the passenger side of the block I decapitated in the process, and tossed in some new plugs).
Anyway, now my car runs quite rich (from the smell of things), and idles like crap--dieing way too often for my liking. Any thoughts on this one? Maybe something to do with the O2 sensor?
Prior to the install my idle was slightly rough and I'd get the SES after 30-40 minutes of highway cruising, which made me suspect the EGR. Could an EGR problem have been greatly amplified?
Any help?
Thanks!
Jeremy
Old Apr 1, 2002 | 11:48 PM
rezinn's Avatar
What code does your computer give you?
Old Apr 2, 2002 | 12:13 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Germ, Your in St. louis? Check out mofba.net. It's the MO f-body Association. Sounds like a code 32 or 34.
Old Apr 2, 2002 | 01:13 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Where is your O2 sensor?
Mine is in the collector of the Edelbrock TES headers and works fine unheated. Even when my O2 was out it didn't run terribley rich though it failed emissions in OH.
You need to check it out with a scanner to see what's up.
Wesly_66
Aug 26, 2015 09:55 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
