Hone stock runners?
Old Apr 2, 2002 | 11:54 AM
brian89transam's Avatar
Hone stock runners?
With all the controversy over which runners are the best I think I'll stick with the stock ones and buy a new base and port the plenum. I have been trying to figure out a way to make the stock runners a little better. I was wondering, What if you took a small engines cylinder hone(like for a 5 horse brigs), and tried to bore the runners out a bit? It would atleast clean out all the carbon deposits and smooth out the walls. Has anyone tried anything like this? Do you think it would help much?
Old Apr 2, 2002 | 12:09 PM
Guest
Guest
Posts: n/a
The stock runners are thin enough that they will dent if you look at them wrong, so increasing the size isnt really possible. They are also pretty smooth as is. Honing them I think would be more than a complete waste of time.
Old Apr 2, 2002 | 01:03 PM
Drew's Avatar
but imagine how cool it would be to have transparent runners.
Old Apr 2, 2002 | 03:10 PM
oh well. Just another idea down the drain.
Old Apr 2, 2002 | 03:45 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
On both my Vette and IROC I've opened up the tops of the runners and port matched the plenum. It may have helped a little but I don't have time slip data as I did other intake mods at the same time.
I have a set of AS&M LT runners going into the Vette soon. I would suggest them if you are going to a larger base.
Someone on this Forum has siamesed the stock base runners and that is what I am doing this week. The report was that it was worth about 20hp or so without losing any low end torque.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Genopsyde
Oct 7, 2015 08:35 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
