350 tpi question.
Old Apr 2, 2002 | 12:53 AM
HondaHunter's Avatar
350 tpi question.
i'm in the middle of building up a fairly mild 350. i have a couple of questions. first, i was wondering what kind of performance i could get out of a stock 305 top end on my 350. i'm not really looking to build a race car, just something that'll be a little quicker than the stock 305. i just wanted to know what kind of problems i would run into and what kind of performance can be obtained with this set up. thanks
Old Apr 2, 2002 | 02:01 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
What mods to the motor? What car is it going into? What tranny & gears?
With a mildly built up 350 TPI you can pretty easily get 300+hp. Check out my site to see what it took to get my L98 to that number.
Old Apr 2, 2002 | 03:03 PM
the motor is a 350, 30 over, stock bottom end, new bearings, flat top pistons, new rings, i have headers and exhaust, and a high performance street cam of some sort, i haven't picked it out, i'm still debating whether to use my performer intake and holley 750, or just use my 87 tpi off of a 305 i have. its going in an 84 firebird with a stock 87 700r4 and its got a 2.73 posi. i just need to know if the stock 305 tpi will be able to handle powering the 350.
Old Apr 2, 2002 | 03:39 PM
The L98 Vettes used the LB9 TPI intake. My '88 Vette currently runs low 13s building about 300hp with only a gutted MAF, 52mm TB and ported plenum for intake work (of course it has a K&N and ram-air).
So you can use the 305 TPI intake, at least initially. If you need more air you can go to a BigMouth base (or siamese the stock base) and AS&M LT runners.
Are you considering upgrading the heads? A good set (possibly ported) will give you at least as much as the cam.
Old Apr 2, 2002 | 05:02 PM
360Iroc's Avatar
I did the build on my TA and the only mods to the Topend were throttle body, bumped fuel pressure, and some air box mods. My motor turned over 400. I think it will be ok. I could get plenty more out of it, if I upgrade my topend. Email me if you have any questions... Pimpjetta@hotmail.com
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
