Match Porting with TPIS Large tube gasket set ?
Old Apr 3, 2002 | 12:41 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I'm in the process of match porting my TPI intake and I wanted to see what some of you have done
First off I have SLP runners and a Edelbrock Base plate
I bought a set of TPIS large tube gaskets
When I went to start on the runners and plenum I didn't really think the gaskets were THAT big but, ... they are much larger then I thought ...they are probly 3-4 /16 of an inch larger than the SLP's as well
I guess my question is did you Go ahead and port the plenum and runners to match the new large tube gasket set?
BTW I will be running a ATI with 10-12 lbs that why I say it might be too big
What do you think?....Any Pic's or you plenum you have done would be cool as well
Thanks for any of your thoughts
Old Apr 3, 2002 | 07:28 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'd open up the runners as much as seemed reasonable. If they have the meat to fully match them to the gasket, then go for it if you have to time. Make it a nice smoothed entry. Then open up the plenum to match that.
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
