To advance or to not advance?
Old Apr 3, 2002 | 10:33 AM
IROC57TPI's Avatar
Read sig for the ride.....
I have added a MSD 6A and a good set of wires. where should I run my timing? Its supposed to be 6* adv. stock, but if I run a wider plug gap and let's say 8* adv. won't I theoretically make more cylinder pressure and therefore more power?
I have a custom PROM from TPIS that has an agressive advance curve already. Could I potentially run into knock retard? I guess I will just have to set it with a scanner and watch the retard.
:hail: I just answered my own question
Old Apr 3, 2002 | 12:39 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
You can advance base timing to what the motor likes as seen by time slips. I like to also use my scanner to assure no knock counts pulling timing at WOT.
With that ignition you should be able to gap to .045" or so. For a little more HP try cutting back the ground electrodes on the plugs. The method is on my site:
http://www.geocities.com/jgkov/index.html
I run a HyperTech coil/cap/rotor in both cars along with performance wires and cut back plugs. I gap them to .045"-.048". My time slips consistently show close to 1mph gain at the traps or about 10hp over non-cut plugs.
Old Apr 3, 2002 | 01:42 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You want to run the minimum amount of timing consistent with your best MEASURED performance. Extra advance beyond that just peaks the cylinder pressure earlier and actually fights the piston coming up.
Old Apr 3, 2002 | 03:52 PM
Bort62's Avatar
and don't cut your plug electrodes.
Old Apr 3, 2002 | 04:09 PM
Ed Maher's Avatar
Car: 04 GTO
If you regularly change/check your plugs there isn't any real harm in cutting back electrodes. I do it myself when bored, only takes a couple minutes w/ a dremel.
Old Apr 3, 2002 | 04:12 PM
Bort62's Avatar
blah, if you like changeing plugs more often than you need too
Old Apr 4, 2002 | 11:46 PM
Kandied91z's Avatar
man mike, i knew you were getting the car painted but red, the body looks different as well.
oh wait that's not the roc.......
Fanatic1074
Oct 3, 2022 05:57 AM
djmarch
Oct 2, 2015 10:41 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Damon
Sep 26, 2015 04:29 PM
