well I see the stock L98 cam specs for 1992 is at a 202 int, 207 exh duration w/ .413/.428 lift.
Here is my situation. I have a spare set of '87 L98 heads and decided to go ahead and port them and throw them on, along with a nice, decent cam. I have worked L98 heads before and seen some awesome numbers, so that is not an issue. Here's the kicker: I declared myself "done" with this car, so budget is an extreme issue. I want to re-use ALL my valvetrain INCLUDING the valve springs. I would like a cam thats not too crazy and that will really love the nitrous.....kind of like what the Comp nitrous cams claim to do. I'm looking at around 218-220 duration on the int. for the cam.
What is the max lift I can run up to w/ the stock springs? I suppose if I MUST replace springs, its not a big deal, but I would like ones that have the stock diameter so that I dont have to do any machinig for them.
Also, I will port and match the base and plenum all together along w/ match to the heads. Is my throttle body going to be a restriction at this point? It is a stocker...but I see they use this on the RJ 502!!! SO I guess not???
What are your recomendations for a cam for me guys? I will replace springs if its absolutely necessary....mods are in sig...dont forget about the spray..I like the nitrous cams I see in jegs/Summit. What about the "TPI" cam from SLP in Summit? I dont have the specs w/ me but I hear good about them.
Where will my bottleneck be at this point?
I believe about the max lift you'll live with on stock springs, espeically used ones that already have been worn is going to be about .460, at least I wouldn't go any over that, loosing .5 hp from staying under .500 will be worth not floating a valve and ruining everything. I dont have a recommended cam but I'd say something with 212/218 duration, 112 LSA, and 450-460 lift or so. As far as your TB forget it, when you break 400hp then get a new one, and you wont with stock (yes even ported) L98 heads.Originally posted by chevyboy07 91
Good luck
hmmm, so anywhere near 218 OR 220 int. duration is TOO much you think? I was leaning upwards around there.
