Stealth Ram Q's
Old Apr 4, 2002 | 11:13 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Stealth Ram Q's
i have read some posts that say that the stealty ram will not fit the '87 + heads... well i am probably gonna get a ZZ4 crate engine... is the Stealth Ram gonna fit this engine?
Old Apr 4, 2002 | 11:21 PM
Bort62's Avatar
The HSR will not fit 87+ heads without Modification would be more accurate.
Just as if you were to use any 86 and older Intake on 87 + Heads, a little die grinder work should solve the problem.
The ZZ4 heads Im 99% sure are the 87+ angled bolt pattern.
So its going to take a little work on your part.
Old Apr 5, 2002 | 02:40 AM
dakkon's Avatar
I'm 100% certain the zz4 has and old bolt pattern bult still has centerbolt valve covers because i have one so the stealth ram should bolt right up but there are other concerns like a small cap dist. and hood clearance im also wondering if any one has done this looks like a great cost effective alternitive to the super or mini ram. Has any one got one yet if so please fill me in.
Old Apr 5, 2002 | 07:13 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The ZZ4 uses L98 Corvette aluminum heads. Centerbolt heads with the old intake manifold bolt angle.
Old Apr 5, 2002 | 08:25 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
thx guys.... like many others i want to get one before the price jumps up a ton... and i will have it before the zz4 if i do so, so i want to make sure it will fit before i order it!
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
