Help, 305 or 350 visable difference
Old Apr 5, 2002 | 01:30 PM
bobs89irocz's Avatar
what is the visable difference between a 305 and 350. i found and engine with tranny for $500 good deal?
Old Apr 5, 2002 | 02:49 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
other than running the casting #'s or pulling a head to check the bore, visually they are the same.
Old Apr 5, 2002 | 03:00 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yup. Different year blocks sometimes had the dicplacement cast into it somewhere, for example most later model blocks have a 5.0 or 5.7 cast into it on the bellhousing flange behind the intake. Some others have a displacement in CI on the lower part of the block above the pan rail.
If you can get the casting numbers, go to www.nastyz28.com or www.mortec.com to look them up.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
