Base timeing with custom chip?
Old Apr 6, 2002 | 08:30 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had to get an ed write customchip for now until i accually know what i'm doing with burning these things (i'm getting confused) andyways what should I set my timing at base? 8*? Thanks
Old Apr 6, 2002 | 11:18 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Use the same principle as with a stock chip, increase till ping or knock counts and then back off a few degrees.
A scan tool showing knock counts under heavy load is the best/safest way.
Old Apr 8, 2002 | 07:24 PM
BOTTLEDZ28's Avatar
Transmission: A4
i have a stage 2 ed wright chip also and i am setting my timing to the stock 6 degrees. let the chip do its job. the chips are burnt to be used with the stock settings on your car.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Exxon Limited
Aug 9, 2015 08:13 PM
