Will factory 1.5r.r's work o.k with hotcam...
Hello everyone, I have an eagle stroker kit for my vette l-98, as you know it has factory aluminum heads, my question is since I have chosen to go with the gm hotcam and try to re-use my factory roller rockers will this negativly impact anything? I am aware that with a 1.5 rr ratio my max lift will be .495 as opposed to the .525 lift with 1.6's, I was told that since i will be retaining the factory heads(even though ported)they could not take advantage of the extra lift anyways. Is this true? I will be getting stronger springs. I tried to find more info in the archives anything similar to my ?. Thanks for any info!!
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
