9.5 Compression Ratio???
Old Apr 6, 2002 | 11:25 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Has anyone checked the actual compression ratio of their LB-9 or L-98? The stock ratio is suppossed to be 9.5 to 1 but my L-98 only checked out at 9 to 1 and my LB-9 checked at 8.9 to 1. Did anyone else get number similar to mine?
Old Apr 7, 2002 | 12:03 AM
Bort62's Avatar
ARE motors (Augustino Racing Engines) Tend to have the opposite problem
CC them out, and you discover your "11:1" 383 was really a 13:1 detonation Machine.
Old Apr 7, 2002 | 08:04 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have an info sheet in front of me that says the LG4 has 9.5:1 and the LB9 and the L98 have 9.3:1 from the factory. Not sure why there would be a difference
Old Apr 7, 2002 | 02:11 PM
rhuarc30's Avatar
Happens a lot on stock engines and gm crate engines. Factory tolerances and such. That's why machine shops make so much money verifying deck heights and cc'ing chambers on performance rebuilds.
Old Apr 7, 2002 | 02:50 PM
Guest
Guest
Posts: n/a
How did you determine those compression ratios?
Old Apr 9, 2002 | 09:25 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I determined the ratio's by cc'ing all of the engine components and then doing the math. I am sure I did the job correctly.
Old Apr 9, 2002 | 09:56 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
was each cylinder consistent with the others? rhuarc30 is right factory is all assy line products so they go on what they figured from the engines that they built for the prototypes and such anything else has a tolerance of probabaly +-.5 :1 from the advertised. and once again thats why machine shops are so pricey
Old Apr 10, 2002 | 10:26 AM
Guest
Guest
Posts: n/a
Thats a huge difference IMO.
What sorta numbers did you come up with? Maybe from that we can pinpoint where the discrepancy is.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
