Tpis Enhancer?????
Old Apr 8, 2002 | 09:18 AM
BILZ88350's Avatar
Tpis Enhancer?????
Need some advise. Has anyone used the TPIS --TPS ENHANCER?Is it worth the $89 and does it work????????????????
Old Apr 8, 2002 | 09:33 AM
IROCKER's Avatar
What is it? What is it supposed to do?
Is there a link to it or something.
Old Apr 8, 2002 | 09:43 AM
BILZ88350's Avatar
hey irocker; TPIS CATOLOGUE -P/N 300-260 page 47. IT APPARENTLY BRINGS IN THE VOLTAGE SIGNAL QUICKER TO SIMULATE WOT. IVE NEVER HEARD ABOUT IT BEFORE.
Old Apr 8, 2002 | 11:48 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
No, it is a complete waste of money. If you want to bring in WOT sooner you can set it in the chip, but even if you do, there is no 'performance' gain. WOT is still just WOT.
This subject has been beaten to death both here and in the PROM board in the past if you want to do some more reading as to why it is such a bad idea to 'fool' sensor signals to the ECM.
Old Apr 8, 2002 | 05:37 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i purchased this enhancer from TPIS, and im not really happy with it. i used to get 1.9 sec 60fts in the vette, but after i installed the enhancer, alls i get is wheelspin. it sends to much voltage input to the ECM to early, resulting in my tires spinning at launch. im pretty sure my tire spinning problems are because of this unit, because when i remove it, i dont spin nearly as much. maybe if i had drag radials i could test it further, but for now, im ditching it. Heres another side of the arguement, though. Corvette Fever magazine dyno tested this peice on a stock 84' Crossfire Vette and came up with about a 10hp increase. this was only recorded on the extreme top and bottom of the power curve, however. the midrange actually lost a few hp.
Old Apr 8, 2002 | 06:54 PM
Ed Maher's Avatar
Car: 04 GTO
Any kind of gain would have to be because of a bad adjustment or sensor or something. To the ECM there is no difference in what it does past a certain %TPS (which is when it enables PE) This value is pretty muich never higher than 70% for anything, which is well below WOT for any working TPS. Even the pump shot table, as mysterious as it is, only has a 50% TPS range in it.
Old Apr 9, 2002 | 05:02 AM
BILZ88350's Avatar
I PHONED TPIS AND THEY STATED THAT ITS ONLY FOR A BONE STOCK CAR. IF YOU REWORKED THE E PROM CHIP OR HAVE A AFTERMARKET ONE IT WOULD BE USELESS.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
