cleaning injectors on TPI
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Has any one used the injector cleaner that jegs or summit had that attached to the fuel rail.
It was like a freon set up. You attach the hose to the top of the can, then attach the hose to the fuel rail. You pull the fuse on the fuel pump and start the car. The motor runs on the stuff in the can ( no fuel) When you are done you replace the fuse.
Dose any one have this cleaner anymore. and does it work on the injectors.
Does GM do this type injector cleaning.
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
I have seen it when I worked in the parts stores it was usually sold as part of a kit kinda expensive but it was intended for garages that do this more often than an individual would, its supposed to be just like running carb cleaner through a carb or a really strong injector cleaner that you put in your tank.
hth
hth
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
