cheap intake question
Old Apr 9, 2002 | 03:07 PM
youngin's Avatar
I have been looking around alot for what cold air intake set-up would be the best for the best price. And other than the SLP one it seems like you basically have to make your own. Alot of you guys have fabricated your own with aluminum and plastic. The question I have is can you just clamp the K&N filter onto the stock tubing and have an improvement? If so what size filter would be the best to put on there and what is the part number.
I want to do something with my intake and I don't know whether to just stick one on the end, cut holes in the airbox and put a stock fitting air filter or fab up a whole cold air intake.
Old Apr 9, 2002 | 05:14 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I made mine out of PVC and rubber hoses from LOWES. I got it for $26+change. This price does not include my K&N filter = $50 Its easy to do. Took me less than an hour, and it works really well.
1. Get parts. 3" PVC/2 rubber 90* bends/and a filter(K&N,
holley,etc)
2. Measure and cut a peice of PVC.
3. Unbolt the Charcole canister and relocate it. Take out the
brakets that the canister and filter sat on.
4. Cut a hole in the sheet metal where you want to route the
rubber tubing.
5. Stick one 90* bend on the TB achordian(sp) hose.
6. Put your PVC into that.
7. Attach the other 90* bend into the hole you cut.
8. Put the filter on the end of that.
Done.
Try using the search engine on this board in the future.
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
