Fuel line Size
Old Apr 10, 2002 | 03:36 AM
Bort62's Avatar
Fuel line Size
What Size braided line should I use Doing a TPI swap On my Lg4 Car.
-6 AN right ?
Also, Do I need to Flare the existing hardlines to hold the Pressure ?
What Fittings will I need to Connect the Fuel rail to the Steel braided, and then the braided to my existing lines ?
Thanks.
(look, I actually asked a question)
Old Apr 10, 2002 | 03:39 AM
Bort62's Avatar
Also, Earls or Areoquip.
Earls is alot more expensive... Why ?
Old Apr 10, 2002 | 05:51 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I suggest you get all the lines from a salvage yard. Look for any fuel injected F-body, even a V-6 has the lines you need. I paid like $20 for mine.
Old Apr 10, 2002 | 07:38 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
good idea John
the fuel lines in your car may be too small for a fuel injected intake.it would be cheaper to get all of them out of a salvage car than to buy all new braided line.that ****s $$$$$
Old Apr 10, 2002 | 08:53 PM
Bort62's Avatar
Yes but you fail to see that I don't want Some nasty *** Old Rubber lines out of a junkyard.
PLus, 3/8" Line is plenty for supply.
Old Apr 10, 2002 | 10:12 PM
TheCamel's Avatar
If you ever plan on running it at the track and you get into the higher brackets where the rules get a little stiffer you have to have solid line, Steel braided is ussually looked down upon by certain inspectors. You also have to realize the pressure that will be on the line, make sure you get the correct fittings for a high pressure line
Sean
Old Apr 11, 2002 | 11:23 AM
Bort62's Avatar
You don't need Solid line all the way to The Rails.
This will only Run fro the Existing solid line to the rail.
Old Apr 11, 2002 | 06:35 PM
Engine: 4.0L
I wasn't talking about the "nasty rubber lines" at a junkyard. I was referring to the hard lines from the tank to the engine bay, those are the ones you need to keep it simple.
Old Apr 11, 2002 | 09:45 PM
Bort62's Avatar
Ill Consider it John, but that still dosent solve My Hardline to fuel rail problem...
Old Apr 12, 2002 | 12:18 AM
Engine: 4.0L
Then you get the rubber lines from the dealer.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
toronto formula
Nov 10, 2015 06:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
