What will more compression give?
Old Apr 11, 2002 | 02:23 AM
Torqomeo's Avatar
What does higher comp ratio on a L98 give out moer HP or more tourqe. Im thinkin a couple points maybe. the stock is 9.3:1 which is kinda sucky.but if it was say 10:1 would i see power similar to a LT1??
Old Apr 11, 2002 | 05:16 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if you raise the compression you should see a gain accross the whole rpms band
that would lead to higher torque AND high hp
though the way you do the compression can also mean a difference on how much power can be made
like going with a dome piston.
that will raise your compression but if I remember right you are then going to have a worse combustion properties then if you mill the heads put a flat top or dish piston in there.
Old Apr 11, 2002 | 10:02 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
With out switching to aluminium heads your gonna have detonation! You can't just raise the compresion of an engine and expect extra horses to come flying out. An engine must be built around the choosen compresion, and a stock engines components are built to handle 9.5:1 and no more. I don't want to come across like a hard azz, but if you do this to an engine you won't realize the mistake you have made untill it is way too late, that is unless you plan on running av. gas.
FormulasOnly
Jul 23, 2018 08:47 AM
gixxer92
May 18, 2017 11:20 AM
Giocio
Oct 1, 2015 12:20 PM
luvofjah
Sep 26, 2015 08:28 PM
WhteRbt
Sep 21, 2015 09:48 AM
