anyone ever reroute wiring harness under plenum
Old Apr 11, 2002 | 08:37 PM
BOTTLEDZ28's Avatar
Transmission: A4
i am putting a 350tpi togehter and want to clean it up a bit and decided to try and run the injectors wiring harness' under the plenum on the fuel rails. the passenger side seems a bit tight and i am not sure if the starter wires will make it ot the starter now. anyone have pictures of cleaned up wiring for the tpi
Old Apr 13, 2002 | 12:48 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Ive seen the painless wiring kits for the same set up your trying to do but as far as the stock stuff fitting I dont think it will but never know unless you give it a shot
Old Apr 13, 2002 | 08:33 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Yes, I routed my Painless under the plenum. Makes for a much neater appearance. Sorry, no way to post pics.
Old Apr 14, 2002 | 09:45 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I routed my stock harness under the plenum. The starter wires are really a tight fit, but it can be done.
Sparks a flyin'
Old Apr 15, 2002 | 12:58 AM
Gruvin84SS's Avatar
having no pictures to go by, i routed mine there under the plenum when i installed my TPI in my SS.
Old Apr 15, 2002 | 01:18 PM
BOTTLEDZ28's Avatar
Transmission: A4
I attemtped to do it last week3nd and i ended up going back and putting them in the stock location. the wires where just too tight ffor comfort. the starter wires were real tight and i would have had to lengthen the alt wire. all well
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
