Ram Air
Old Apr 11, 2002 | 11:34 PM
iroc_cragg's Avatar
Ram Air
Hey
I have a 1985 IROC Z Camaro with a 305 TPI engine. I am interested in making a home made ram air kit for my car. I am a bit worried that I might wreak somthing though. How hard is it to make the home made kit. For you guys that have make the ram air kits what kind of performane basline in HP do u get. I was thinking around 5-7HP....
Well tell me a bit about the ram air kits.
Post ur pics of the ram air
Thanks alot for the help
http://camaroz28.cardomain.com/id/56424
Old Apr 11, 2002 | 11:56 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
I haven't done it but it shouldn't be that hard. Most people who have made their own set-ups have got by just fine with 3" air conditioning duct tubing. Someone here, i don't remember the name, had a sweet set-up made polished 4" custom mandrel-bent pipe. SLP also makes a kit but its a rip off. It'll give you a respectable gain over the stock aircleaner....more so for us firebird guys.
Old Apr 12, 2002 | 06:54 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I use the Ram Air set-up to feed the blower, works great , It gave me an extra PSI of boost.
CHeck out my site for more pics:
http://www.lbsz28blown.cz28.com
Old Apr 12, 2002 | 12:34 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I just cut off the bottoms of the air filter boxes, leaving about 2-3". I ran 4" dia Al flex tubing (like large dryer vent tubing) doen from the boxes, in front of the radiator and behind the fogs. I was able to "form" the flex tubing to fit between radiator and the corss-piece so that no cutting other than air filter boxes was necessary. This means the ducting is square within the boxes, rather flat down below and oval behind the fogs. If you want to be "neat" you can form a scoop to blend from the ducting to the fog light openings. For a few $$ at Home Depot you can't go wrong.
Your estimate on HP gain is good, and then in the last 1/8mi.
The only down-side is that I have to clean the K&Ns more frequently (no screens). I've never been bothered by water getting through the tubing and K&Ns; I've driven in hard rain storms and through standing water.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stangski09
Nov 14, 2015 01:27 PM
edoff13
Sep 11, 2015 03:55 AM
09ave
Sep 7, 2015 06:03 PM
