setting the base timing
Old Apr 13, 2002 | 04:18 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
People have said in setting the base timing that you have to disconnect the ESC(I think thats what it was called) but in a book I have all it shows is when the vehicle is running you connect the A&B terminals while adjusting the timing then before shuttingoff the engine you remove the jumper and shut the engine off. Which is right for an 89 L98?
Old Apr 13, 2002 | 05:43 PM
Guest
Guest
Posts: n/a
I've never tried jumping the terminals. There should be a single wire thats tan with a black stripe and a single wire weatherpack connector that you can disconnect for setting the timing. I dont know where it would be on your monte since they didnt come that way
The painless harness has the connector about 6-8" from the ECM itself. The factory F-body harness its more like 4' from the ECM.
Old Apr 14, 2002 | 10:29 AM
DrekkenX's Avatar
My friend and I just set my base timing yesterday. We did disconnect the EST (Electronic Spark Timing) and just turned the damn distributor to the desired advance. I think what the book is telling you is how to adjust the Electronic Spark Timing (computer controlled) and what you wanna do is adjust your base timing. Good luck
- Tom
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
