700r4 shifts to soon
i was wondering if there was anything i could do to make it shift a little later. and the tv cable is adjusted right.Can i put different springs in the governor to make it shift later??
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You can change the weights & springs on the governor. This will alter part & WOT shift points. There is a kit available from PATC & other trans shops.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
