I need a flywheel and clutch
Old Apr 22, 2002 | 11:53 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I am getting ready to install my new engine into my 92. The car is original down to the fading paint! THe stocker is a 305/T5 combo. I am installing a 383cid (internal balance) with the block being of the old stlye rear main oil seal. The block is a 1980 core. I would like to retain my T5 until i can get up enough money for a T56 or a Tremec.
I am hoping some of you can advise me to what flywheel i need.
I have heard somewhere that a flywheel/clutch assembly from or for a 82-85 camaro will work with the 92 trans. Is this correct? If not can anyone steer me to the correct combination. Thank you.
Old Apr 22, 2002 | 12:39 PM
87RS402's Avatar
All you need is a 153 tooth (12-3/4") flywheel for a two piece rear main. Your stock 92 clutch will work fine or you can upgrade to an aftermarket performance clutch.
It's that easy.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
