Can Dextron III be used in place of Dextron II ??
Old Apr 24, 2002 | 12:24 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'm just wondering if Dextron III is compatable with a tranny that requires Dextron II ??
Old Apr 24, 2002 | 12:27 PM
Pro Built Automatics's Avatar
Dexron II & IIE, was replaced with Dexron III. It will work anywhere Dexron is required.
Old Apr 25, 2002 | 12:17 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
The reason I ask is because I still see some fluids that are offered in both Dextron III & II. Like Red Line they offer a III & II. Will I get better performance using the recommended II or would the III or would it even make a difference??
Old Apr 26, 2002 | 12:51 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
As explained to me -
You can use Dexron III in a car that requires Dexron II. You can actually use anything higher that what is asked for. You cannot, however use Dexron II in something that calls for Dexron III. You cannot put in something that is lower than asked for.
When I put in my new clutch, I used Dexron III. It said to use II.
Another thing, is it me or is it normal to use Automatic tranny fluid in a manual gear box???
KZad
Old Apr 26, 2002 | 02:44 PM
82camaro's Avatar
Car: 82 camaro SC
Dexron III replaced dexron II. I haven't seen dexron II for a very long time. Yes some manual tranny's use ATF.
Old Apr 28, 2002 | 06:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
and some transfer cases use trans fluid also, namely the new process 208
Linson
Oct 24, 2025 02:00 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
