Speedo Gear Confusion
Old Apr 27, 2002 | 12:07 PM
fbody dude's Avatar
Car: 92 Camaro
I changed my 2.73 rear end to a 3.42 from an 86 Firebird. The speedo gears have got to go. I have done a search and have read Omar’s excellent answer. Seek out Omar’s response if you want a good answer to speedo gears. Also, I have used the speedo calculator at 700R4.com. All these resources are telling me that I need a 15t and a 41t set of gears. However, when I called two of my local dealerships, they said I need a 7t and 19t set of gears. Which is right? Also, the ratio between the two is 3.7. (15/41=3.7 and 7/19=3.7) Can I use any set of gears as long as I keep the same 3.7 ratio?
Old Apr 27, 2002 | 01:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Dude,
I think the dealer is full of shiznik!
You probably ran accross a couple of my posts and read Mr. Omars responces:rockon:. Ypu should get the grey 15 tooth drive gear (some 700r4's have them already) and the 41 tooth driven gear, I think its red.
Good luck!
SSC
Old Apr 27, 2002 | 02:23 PM
fbody dude's Avatar
Car: 92 Camaro
SSC,
Thanks. I just wanted some kinda of confirmation. My cousin deals with the car dealerships alot. He said anytime they have exactly the same answer, they are probably just reading it off a computer and don't know what the best answer is. I would rather trust you guys and gals who have done this before.
Thanks Again.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Jorlain
Oct 8, 2015 01:57 AM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
