Speedo not working, after T-5 swap.
Old Apr 28, 2002 | 08:57 PM
Cm87pta's Avatar
Hey, i've got an 87 T/A, i swapped from a 700-r4 to a T-5. I get a code 24, which is the vehicle speed sensor, because the speedo doesnt work. What is needed to make the speedo work, and where can i get one.
Old Apr 29, 2002 | 12:07 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need the vehicle speed sensor (VSS) that plugs into the left rear of the T5. It'll be an electronic one for 87-89 Firebirds. Whats in that hole now? The one from the automatic is different and wont fit in there.
Old Apr 29, 2002 | 08:46 PM
Cm87pta's Avatar
Well it has the male end for the hook up but there as you said the auto wire wont hook up to it. But where can i get the electronic vss, Dealership and where else?
Jorlain
Aug 24, 2022 05:11 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
