1988 10 bolt rebuild options
Subscribe
Apr 30, 2002 | 08:05 PM
My '88 10 bolt 2.73 open rear is going to rust away if I don't do something with it. I had a 1984 3.23 rear I bought for $150 put in but I'm not pleased with it. It whines a lot at times, mostly when I am coasting. I know it won't last too long.
My 2.73 has drum brakes and I will just keep those. I want 3.73 gears and posi. I've heard good things about Auburn gears and Eaton posi units.
What all will I need to buy to make it as bullet proof as possible? I don't want to spend over $2000 on a brand new complete rear. Please be specific because I know very little about this area of the car. Thank you.
:hail:IROC-Z
Reply 0
Apr 30, 2002 | 08:23 PM
Re: 1988 10 bolt rebuild options
:hail:IROC-Z
I just rebuilt mine, and installed it Sun. I spent about 1,000.00 and did ALL of the labor. Would I do it again? NO. I would have bought a 12 bolt or a 9' ford for it. And I got some deals on some parts. New eaton posi, moser 28 spline axles, and an install bear kit with axle bearings and seals. From gearsareus.com A little over 700.00 shipped. New 410 motive performance gears 127.00 shipped[ ebay]. New 10 bolt summit girdle, 115.00 shipped [ ebay]. I wish now I would have went with the 12 bolt, being I had a 10 bolt from a 2nd gen , I could have used the brakes from. They're won't be a lot of differance if you can't do the work yourself. Probably the shipping on the whole rearend.
Reply 0
Apr 30, 2002 | 09:43 PM
If you want is as bullet proof as possible, you really need to just toss the stock 10 bolt.
If you want to strengthen the stock 10 bolt, get some 2 series 3.73 gears and install a powertrax lock-right locker(very streetable), install all new timkin bearings, synthetic lube. On further, you could have the axle tubes welded, install a support cover, solid pinion spacer, ect. The problem is that you will make the 10 bolt stronger, but your engine could still rip that 7.5 inch ring gear apart.
Reply 0
Subscribe
